Contenido faltante en la página principal de discourse
I have updated discourse and font page were missing content. Single topics and admin control panel are still working normally.
http://forum.openbim.com.vn/
http://forum.openbim.com.vn/t/cung-nghien-cuu-ung-dung-dynamo/1852
I installed discourse with WordPress on the same machine follow this post:
https://meta.discourse.org/t/running-other-websites-on-the-same-machine-as-discourse/17247/59
This is my app.yml
templates:
  - "templates/cron.template.yml"
  - "templates/sshd.template.yml"
  - "templates/web.socketed.template.yml"
 ## Comment out the following lines if you wish to add Lets Encrypt for your Discourse install
 # - "templates/web.ssl.template.yml"
 # - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
expose:
  - "2222:22"
# - "80:80"   # fwd host port 80   to container port 80 (http)
# - "443:443" # fwd host port 443   to container port 443 (https) (ssl ready)
# If you want Discourse to share a port with another webserver like Apache or nginx,
# see https://meta.discourse.org/t/17247 for instructions.
# any extra arguments for Docker?
# docker_args:
params:
  ## On 1GB installs set to 128MB (to leave room for other processes)
  ## on a 4GB instance you may raise to 1GB
  #db_shared_buffers: "256MB"
  ## Set higher on large instances it defaults to 10MB, for a 3GB install 40MB is a good default
  ## this improves sorting performance, but adds memory usage per-connection
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  ## TODO: How many concurrent web requests are supported?
  ## With 2GB we recommend 3-4 workers, with 1GB only 2
  ## If you have lots of memory, use one or two workers per logical CPU core
  #UNICORN_WORKERS: 3
  DISCOURSE_DEVELOPER_EMAILS: 'vubaduy125@gmail.com'
  DISCOURSE_HOSTNAME: 'forum.openbim.com.vn'
  ## TODO: Uncomment if you want the container to be started with the same
  ##       hostname (-h option) as specified above (default "$hostname-$config")
 ## NOTE: 'true' is the only valid value here, any other will be ignored
  #DOCKER_USE_HOSTNAME: true
  ## TODO: The mailserver this Discourse instance will use
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org         # (mandatory)
  #DISCOURSE_SMTP_PORT: 587                        # (optional)
  DISCOURSE_SMTP_USER_NAME: postmaster@forum.openbim.com.vn      # (optional)
  DISCOURSE_SMTP_PASSWORD: d081e5dce7663f3dce367a72f239e80b      # (optional, WARNING the char '#' in pw can cause problems!)
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## The Lets Encrypt email will allow you to register a FREE SSL certificate if you added the Lets Encrypt template, comment it out if you have set this up
  # LETSENCRYPT_ACCOUNT_EMAIL: email@awesomedomain.com
  ## The CDN address for this Discourse instance (configured to pull)
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
## These containers are stateless, all data is stored in /shared
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## The docker manager plugin allows you to one-click upgrade Discourse
## http://vietbim.net/admin/docker
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/angusmcleod/discourse-topic-previews.git
## Remember, this is YAML syntax - you can only have one block with a name
run:
  ## If you want to configure password login for root, uncomment and change:
  ## Use only one of the following lines:
  #- exec: /usr/sbin/usermod -p 'PASSWORD_HASH' root
  #- exec: /usr/sbin/usermod -p "$(mkpasswd -m sha-256 'RAW_PASSWORD')" root
My nginx config in /etc/nginx/conf.d/discourse.conf
server {
        listen 80; listen [::]:80;
        server_name forum.openbim.com.vn;  # <-- change this
        location / {
                proxy_pass http://unix:/var/discourse/shared/standalone/nginx.http.sock:;
                proxy_set_header Host $http_host;
                proxy_http_version 1.1;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-Forwarded-Proto $scheme;
Help me plz, i very appreciate it.
Have you tried safe mode?
1 me gusta
okay, let me try it out. Thanks
Logo and top menu showed up. But still missing content. I wonder is there any way to reinstall discourse ?
I would try a rebuild without this plugin, in case there is a server side incomatability.
3 Me gusta
Wow, that is correct. My site is working normally now. Thank you very much. :slight_smile:
be sure to mention this issue at:
https://meta.discourse.org/t/topic-list-previews/41630
7 Me gusta
Este tema se cerró automáticamente después de 2727 días. Ya no se permiten nuevas respuestas.
