[Gamification] Sidebar icon no longer shows
Greetings,
The sidebar icon for the “Gamification” plugin no longer shows on my website. Here is what the HTML shows:
A couple things I think you can check… if you visit /admin/customize/components/ does the discourse-material-design-icons-outlined theme component need an update?
if that’s up to date and it’s still missing… if you remove the icon and try to add it again, does it appear in the menu here:
The metal icon does it show as an option but I found a trophy one I like! Thank you
