typeoneerror
(Benjamin Borowski)
Dezembro 13, 2017, 6:18pm
1
Is there no way to add custom links to the navigation or next to the logo without self-hosted Discourse? If not, where would you recommend we put external links that need to be super obvious for new users?
A pinned post such as https://meta.discourse.org/t/welcome-to-meta-discourse-org/1?
Use Customize > Themes to inject some JavaScript in </head> to add a link?
I’d love to see the Theme editor use Liquid or another templating system so we can do more with hosted Discourse. Many of our clients we’re building forums for would love this.
jomaxro
(Joshua Rosenfeld)
Dezembro 13, 2017, 6:36pm
You can add custom links to the navigation/next to the logo on hosted Discourse.
A quick search led me to the following (there are likely more):
This feature is now available as a dedicated theme component .
Want to add a new link right next to search icon on header? Follow below steps:
Add this JavaScript code to your site theme
Go to Admin
Customize
Themes
Select the theme you wish to customize
Edit CSS/HTML
</head>
<script type="text/discourse-plugin" version="0.4">
const { iconNode } = require("discourse-common/lib/icon-library");
api.decorateWidget('header-icons:before', helper => {
return helper.h('li', [
he…
https://meta.discourse.org/t/custom-nav-header-like-discourse-org/21053
We’ll be implementing a black header with one link that reveals a menu of more links, like this:
[image]
In Admin > Customize > CSS/HTML, create a new customization. Remember that you can have multiple customizations active at the same time, so it’s a good idea to use many of them instead of one giant one for everything. For this custom header, create a new customization called “Header Nav”.
[image]
To implement this sample nav, we need some CSS, HTML, and javascript to show and hide the d…
2 curtidas
typeoneerror
(Benjamin Borowski)
Dezembro 13, 2017, 7:19pm
3
Fantastic, thanks @jomaxro ! I don’t think I realized what the “Header” section of the template was for. This is exactly what I was looking for.
3 curtidas
HAWK
(Hawk)
Fechado
Dezembro 15, 2017, 5:01am
4
This topic was automatically closed after 32 hours. New replies are no longer allowed.
