Custom Header Links (icons)
:discourse2: Summary Custom Header Links (icons) will allow you to easily add linked icons to the Discourse header.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-icon-header-links
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Screenshots
Desktop
Mobile
Settings
This component includes a theme setting that allows you to add as many links as you want, determine their icons, and decide which devices they show up on!
Name Descriptions
header links List of links with the following properties: title, icon, URL, view and target
add whitespace If checked, this will add some whitespace between the default Discourse header icons and the custom icons added via this component
Svg icons Include FontAwesome 6 icon classes for each icon used in the list.
Notes:
If the icon you want to use does not show up, then add it to the svg_icons setting in the component. If you add new icons, they need to be prefixed with FontAwesome 6 prefixes like fab, far and fas.
Credits
This is based on @techAPJ’s awesome tutorial here: (Superseded) Add new link on header beside search icon, and on @vinothkannans’s Brand header theme which was a great reference for the structure of this component.
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
How are theme setting fields created?
Header Submenus
Can I add a icon and link back to my homesite at the top bar
Login Required activated - after successfull login it transfers you to nonexisting page
How to use my own SVG icons in Custom Header Links theme component?
Adding a custom Link/Icon to the discourse header
Introducing Font Awesome 5 and SVG icons
Add custom buttons at the top of the site
Custom Buttons with own functions
Link to external site remains in forum context somehow
Is it possible to add an icon to create New Topic in the navbar?
Custom Admin Toolbox
2021: The Year in Review
External Links Icon
Customizing your site with existing theme components
Show "new topic" when not logged in
Help changing Help Guide Permalink
Customize the header with links, icons, or menus
Updated Custom Header Icon: Post Data via URL
Nextcloud support
User custom field toggle for sidebar (SFW Mode)
Generic URL for private messages?
Discourse Mingle
How to add a link icon to the header
Add button in header for logged in users
Use decorateWidget to add text link to header
Visiting /admin/upgrade may lead to a server error
How to add a directory of people/businesses to my theme?
How to make Navbar SVG icons white?
Add a link to user profile in the navigation
Adding icons rather than text
Clickable Social Icon Links on Profile
Create hyperlink from home logo
Upcoming Header Changes - Preparing Themes and Plugins
Left side hamburger menu on mobile
Air Theme
How to Integrate a Custom Plugin in discourse UI
How to Disable ALL User-to-User DMs/Chat without breaking Other Features?
Custom Header Links
Disable personal message between members
Discourse Mingle
How can I add a button to the header?
Custom Homepage for Groups
Disclaimer section on the "about" page
How to remove iconified header links from mobile?
Header icons color on mouse hovering issue
Link on Top header to Go to Home page of main site
Missing custom header link icon after update
How to add a "button" which composes a pre-filled topic
Using Discourse to Build a Blog, Reddit, X or Facebook-Style Scrolling Platform
[PAID] Moving the Anonymous icon onto the header
Category for Threads with zero replies?
Plugin: add a menu icon (next to search)
Adding a link into the mobile header
How to create a dynamic header link?
(deprecated) Plugin outlet locations theme component
Looking for a freelancer to implement a custom Discourse theme (based on an existing mockup)
Problem with beta6: Header Link Theme Component no longer working
Discourse messaging guide for new users
Insert Link to External Website
My 2nd Discourse forum, 2 years after the first one
I’m having a similar issue as a few people mentioned above where the icon is not showing, but I can still click the button. I made the edit to the icon setting so that it says (for instance) “fab-facebook-f” rather than just “facebook-f”. For Twitter and my other website, I have no issues, but for Facebook and LinkedIn, it’s still not working.
I figured out Facebook, but still can’t get LinkedIn. Also, is there any way to make a custom icon? Could I upload my company’s logo and use it as an icon?
Me too – with Discord icon.
How come I don’t have ‘svg icons’ section in latest version?
I have this:
That settings screenshot looks like the Custom Header Links - #84 component, which is for showing text links not icons.
I can see how the components are named in a confusing way:
  • https://github.com/discourse/discourse-header-links - icon links (this topic)
  • https://github.com/discourse/discourse-custom-header-links - text links (Custom Header Links)
Maybe you should add icon to this one’s name @Johani?
Ah this resolved it, indeed. Yep - super confusing. Rename would rock!
EDIT: Recent update also seemed to ninja change discord’s class name to include fab- in between it (eg, if you’re wanting to change the icons color; which @OP would make a great native feat - was a bit hard to catch).
For Linkedin you can use fab-linkedin as the icon name in this setting
but since that icon is not included in the default set of icons that Discourse uses, you will also need to add it to the other setting in the component.
The result looks like this for me
Sure, there’s a section in this topic about adding custom icons.
Once you have that setup, you’ll be able to use any custom icons you add in this theme component. Please have a look there and let me know if you run into any issues.
I’ve made that change along with a couple of other implementation improvements here
https://github.com/discourse-com/discourse-icon-header-links/commit/f6fbef18af2e1a06fcd68c9199df6c337fca2ce9
The new update adds unique prefixed classes to each link based on the title you use. So, for example if you use
facebook, fab-facebook, https://facebook.com, vdm, blank
the link will have the class
header-icon-facebook
The template is header-icon-ICON-TITLE
Which you can then target with CSS like so
.d-header-icons {
  .header-icon-facebook svg {
    fill: #4267b2;
  .header-icon-twitter svg {
    fill: #1da1f2;
  // add more icons here
which would result in something like this
colored icons
Thank you for your help. I tried using “fab-linkedin” in both the “Header Links” and “Svg Icons” categories. As seen in the picture, it is still not working for whatever reason.
The grey circle is where the LinkedIn logo would be. Any other ideas how to fix it?
I’m not entirely sure why that’s not working for. Here are what my settings look like
Facebook, fab-facebook, https://facebook.com, vdm, blank
Twitter, fab-twitter, https://twitter.com, vdm, blank
LinkedIn, fab-linkedin, https://www.linkedin.com, vdm, blank
and
fab-facebook
fab-linkedin
fab-twitter
and here’s what I’m seeing
Can you please try the same for the linkedin icon and let me know if your issue presists?
This is what I have been trying, and I have tried different icons as well. Here is how I have it currently.
Settings:
Website:
The only ones working are the ones that don’t use “fab-”, which seems weird. Let me know your thoughts.
Hi Michelle,
Since you are a customer, I went in and had a look at your site and fixed the issue there for you. I updated the theme component and set the correct settings for the icons, they should all work now.
It looks great now, thank you!
One more question/ request; I initially had these links opening in a separate tab, but now they are opening in the same tab. The setting is already set to “blank”, how else can I change this?
This looks like a regression, we’ll look into it and have a fix soon.
Indeed. I accidentally left out the target attribute in the recent changes.
No action needed on your side. I fixed the component and updated it on your site. So everything should be all set now. Thanks for reporting the issue :+1:
Hi,
Custom icons are on the right of the login and sign up button, and I think they would fit better on the left, as they usually are.
I can get some version 4.7.0 icons from Font Awesome Icons to work just by typing a name (e.g. car) in the correct part of “Header links”. Some icons don’t show (e.g. fa-comments-o). Some don’t need me to use “Svg icons” (e.g. home) and some do (e.g. car).
None of the version 5 icons which I’ve tried from Find Icons with the Perfect Look & Feel | Font Awesome have worked. I’ve put the fa- name into “Header links” and “Svg icons” to no effect. The fab-facebook (etc) icons which were there by default do work though.
What am I doing wrong?
Edit: I edited the first paragraph for accuracy.
many thanks for this @Johani . works like a charm and gives me an “aesthetical” solution for linking “back to the site” (in my case)
i did however, encounter an issue since i am also using the Left side hamburger menu on mobile component which ends up breaking everything on that part of the .d-header
any ideas on how can i make both work? would really appreciate it
I am also having an issue getting my icon to show up. Not sure what I am doing wrong. Here is what I have under settings:
This is what I end up with:
for the book icon, try without fas-
