האם Google אינו מאנדקס את פורום Discourse – מפת האתר לא אושרה
סיכום מבוסס בינה מלאכותית
Google Not Indexing Discourse Forum – Sitemap Not Approved discussion revolves around Michael82’s issue with getting his Discourse forum pages indexed by Google. Despite submitting a sitemap, only 8 pages are indexed out of 180+, and the sitemap has not been approved. Michael82 has checked robots.txt, sitemap.xml, noindex tags, and Google Search Console, but found no obvious restrictions or issues.
nat suggested checking if Googlebot is in the list of web crawlers and verifying the allowed_crawler_user_agents site setting. Michael82 found Googlebot on the list and added Googlebot, bingbot, and DuckDuckBot to the allowed_crawler_user_agents list. However, Jagster warned that this could be a bad idea, as Google uses other crawlers that don’t declare the Googlebot string. Michael82 decided to clear the allowed_crawler_user_agents list to avoid accidentally blocking any crawlers. The discussion aims to resolve the indexing issue and improve the forum’s search performance.
Hi everyone,
I’m running a Discourse forum (forum.evteam.pl), and I’m struggling with getting my pages indexed by Google. While a few pages have been indexed, most remain unindexed despite submitting a sitemap.
Here’s the current situation:
  • Only 8 pages indexed out of 180+.
  • The number of indexed pages briefly increased but then dropped again.
  • Google Search Console shows 172 pages as non-indexed.
  • The sitemap has not been approved for a long time.
  • Search performance is very low, with barely any clicks from Google.
I have checked the following:
:white_check_mark: Robots.txt – No obvious restrictions.
:white_check_mark: Sitemap.xml – Submitted, but still not approved.
:white_check_mark: Noindex Tags – Not present on key pages.
:white_check_mark: Google Search Console – No manual penalties or security issues.
Has anyone experienced similar issues with Discourse forums? Could this be due to Google’s indexing policies, or is there something I might be missing? Any tips on how to resolve this?
Thanks in advance!
Can you check
  1. <yoursite>/admin/reports/web_crawlers to see if Googlebot is in the list?
  2. the site setting allowed_crawler_user_agents to make sure you are not blocking Google by accident (share this here if possible)
Discourse SEO overview (sitemap / robots.txt) may be a useful topic for you.
תודה על ההצעות שלך!
  1. בדקתי את /admin/reports/web_crawlers, ו-Googlebot נמצא ברשימה, ולכן הוא מייבא את הפורום.
  2. רשימת allowed_crawler_user_agents הייתה ריקה, לכן הוספתי:
Googlebot
bingbot
DuckDuckBot
גם הגשתי מחדש את מפת האתר ב-Google Search Console ואעקוב אם האינדקס משתפר בימים הקרובים.
That could be potentially bad idea — unless you are totally sure every other bots can be disallowed. Google is using a lot crawlers that aren’t declaring googlebot string.
תודה שהסבת את תשומת ליבי לכך! לא ידעתי ש-Google משתמש במנועי סריקה אחרים שאינם מצהירים בבירור על Googlebot.
אקצה את הרשימת ה-allowed_crawler_user_agents כדי למנוע חסימות בשוגג של משהו.
