Firepup650
(Firepup Sixfifty)
17.Май.2024 15:09:32
1
Примеры с поддельными данными канала:
Эта цитата работает корректно
Эта цитата не работает корректно
2 лайка
zogstrip
(Régis HANOL)
24.Май.2024 08:57:56
7
Спасибо за отчёт @Firepup650
Кажется, пришло время, чтобы мы наконец это сделали
closed = true;
break;
if (closed) {
length = i - start + 1;
let raw = src.slice(start + tag.length + 1, i);
// trivial parser that is going to have to be rewritten at some point
if (raw) {
let match, key, val;
while ((match = ATTR_REGEX.exec(raw))) {
if (match[1]) {
key = "_default";
} else {
key = match[4];
Это будет исправлено после того, как этот PR будет рассмотрен и принят
main ← fix-bbcode-parser
merged 08:47AM - 18 Jun 24 UTC
Wasn't quite handling the cases where a closing bracket `]` was used in the valu… e of one of the attributes.
```markdown
[chat quote=user channel="[broken]"]
Would not be correctly parsed because we would _greedily_ use the first `]` as the end of the tag even though it might be a valid character when inside proper quotes.
https://github.com/discourse/discourse/blob/c39a4de139ed9bba4696d44b15cb7569038b5fde/app/assets/javascripts/discourse-markdown-it/src/features/bbcode-block.js#L62
Re-wrote the `parseBBCodeTag` to properly handle the following cases
- A closing tag (aka `[/name]`) which are easy since they don't have any attributes
- An old `[quote=...]` format we used that doesn't uses quotes but still has various attributes of the form `key:value`
- All three valid BBCode opening tag formats we support
- `[name]` without any attributes
- `[name=foo]` with a default value
- `[name foo=bar]` with some attributes
Ended up having to fix/rewrite the few bbcode rules that were using the `parseBBCodeTag` function, namely `d-wrap` and `discourse-local-dates`.
While working on this, I think I also found a way to get rid the of shims we had in place so that plugins could use the `parseBBCodeTag` function.
Reference - https://meta.discourse.org/t/having-a-right-bracket-in-a-channel-name-breaks-all-quotes-from-that-channel/308439
1 лайк
Нашёл эту проблему/исправление после обнаружения связанного бага с загрузкой файлов. Если имя файла содержит символ ‘]’ без предшествующего ‘[’, это нарушает форматирование и не создаёт ссылку. Я предполагаю, что исправление парсера BBCode здесь также решит эту проблему, но упоминаю это на случай, если они обрабатываются в других местах.
zogstrip
(Régis HANOL)
18.Июнь.2024 10:38:52
16
PR объединён, развёрнут здесь, и OP переизготовлен
3 лайка
Эта тема была автоматически закрыта через 3 дня. Новые ответы больше не принимаются.
