I was made aware of this plug-in
https://github.com/discourse/discourse-hCaptcha
but don’t find anything about it here, does anyone have any info on it, using it, examples or reports?
Thank you
Thank you
I can’t find any info on it, but I tested it locally, and everything seems to work fine.
Overview
This plugin is designed to integrate HCaptcha into the sign-up form of Discourse forums. This plugin aims to enhance security and bot protection by leveraging the privacy-centric features of HCaptcha. The setup process is straightforward and consists of a few easy steps.
Installation
- Create an HCaptcha Account:
- Visit HCaptcha to create an account. After registering, you’ll receive a site key and a secret key.
- Setup Local Testing (Optional):
- If you are testing locally, add a new virtual host entry to your hosts file. Include a line like
127.0.0.1 test.mydomain.com. Make sure the domain is valid, even if you don’t own it, to ensure the HCaptcha script loads properly.
- Configure Plugin Settings:
- Log into your Discourse admin panel.
- Navigate to
Admin>Settings>Plugins>hCaptcha (settings).- In this section, add the site key and secret key you obtained from HCaptcha.
By completing these steps, you will successfully integrate HCaptcha into the sign-up form of your community.
Here is some image:
I hope that helps! ![]()
Awesome find! Definitely needs visibility
Very glad for ya for this plugin definitely should became native with multi support.
What is so great on that?
Is it solving a problem that you are experiencing?
Absolutely!
I find this plugin to be broken with 3.3.0.beta3-dev. After clicking registration, it says:
Something went wrong, perhaps this email is already registered, try the forgot password link
I have the latest Discourse version, and I can’t reproduce it in my local (dev) instance. ![]()
I will see to test a production forum in a few minutes.
It works well on a production installation.
Does it happen every time you register?
Yes, it happens every time. I opened up dev tools, and the error is:
{"errors":["You need to be logged in to do that."],"error_type":"not_logged_in"}
when performing a POST to /hcaptcha/create.json
Here is a screenshot:
And I am sure the email is not registered and the problem ceased when the plugin is disabled.
BTW, the domain is https://npuer.life/.
I am not sure whether the problem has to do with using CloudFlare as a CDN, let me do a test. and after a test, the error remains the same.
I can reproduce it on your site. I can see the request pass through Cloudflare, so I can only assume it does something it should not, like caching the page and passing a different forum session.
I don’t know Cloudflare; see in the dashboard if you can disable any optimization for this request.
