It appears that on our (officially hosted) instance, hCaptcha plugin was turned on by default, but (for obvious reasons) was not configured with a hCaptcha account. We just had a user report that they couldn’t sign up and got the message:
There has been a problem with hCaptcha, if this problem persists please contact a system administrator
Turning hCaptcha plugin off seems to resolve the problem.
It is unclear how many users were affected as without signing up, users must find a side channel to contact us. So just noting for other admins.
The hCaptcha plugin is not enabled by default, or it should not be!
Can you check in your staff action logs to see when the plugin was enabled on your site?
Oh sorry, didn’t check properly, it was actually done by another admin, so that’s on us.
Cool! Glad to see this isn’t a widespread problem.
I did just have a closer look and can confirm that on my site, the discourse hcaptcha enabled
site setting is not selected by default which is correct. The plugin is not enabled by default on our hosting (or at least on the starter plan I just tested). However, when you enable the plugin, the discourse hcaptcha enabled
setting is enabled already.
So this does seem to be a case where site owners can shoot themselves in the foot accidentally and without any warning in the admin interface. If you enable the plugin and then enable discourse hcaptcha enabled
, but don’t provide the keys (or provide incorrect keys), no warning is shown in the interface. There is also no guidance on how to get an hCaptcha account.
Instead, an error is shown on the signup form and it’s impossibel to sign up.
I made a pull request to add some more guidance on the site settings to help others avoid this situation. Edit: merged.
Also noticed that there is a warning that should have been displayed on your admin home page to let you know there is a problem with your hCaptcha config. I guess it was not prominent enough?
There is a problem with your hCaptcha site_key
or secret_key
configuration
