Header line-height inconsistency
I’ve seen it with H1s; not sure if it affects all header levels. Anyway, I’ll use the next few posts to demonstrate the issue.
Edit: Here we go:
Does appear to be a specific H1 issue.
It affects reply chains going the other way too; can’t show that here though, as the UI element needed to view the back-chain is hidden.
#This is a very long header that will wrap because I made it long enough by typing a load of random words
##This is a very long header that will wrap because I made it long enough by typing a load of random words
###This is a very long header that will wrap because I made it long enough by typing a load of random words
This should pop up in the parent’s reply chain
this is a reply to trigger the reply chain button to reappear?
A post that will show the reply chain, since you need a spacer post to trigger it to show (thank you @accalia).
Yep, as I thought: the spacing issue’s been sorted :smile:
