I have a glitch related to header-offset with the Announcement Bar component:
With the component enabled, --header-offset is calculated as 120px (header + top bar). On routes where the component is not shown the sidebar mostly adjusts, but sometimes stays with the offset. Not sure what’s the trigger, e.g. here’s different behaviour on different category lists:
Also, when I close the bar, the sidebar stays with the offset, until I scroll or change route.
Would I need to update header-offset manually? Or should this already be updated by default?
