Headless qunit integration tests?
I’d like to run my integration tests via the command line with support for running a subset of the entire test suite. I’m thinking about setting up gulp and phantomjs to run the tests. Something like: node-qunit-phantomjs - npm
Has anyone set something like this up? Any pointers?
We already have a rake task for this…
rake qunit:test
7 إعجابات
Oh, of course! Thanks for that.
I’m trying to work out how to run single tests so I can be TDD.
In general we use the web browser to run single tests using /qunit path
It is doable using the CLI just not implemented yet.
إعجابَين (2)
Here’s a PR that implements that:
https://github.com/discourse/discourse/pull/4268
:slight_smile:
3 إعجابات
Merged it in :slight_smile: good idea,
My dream is somehow to integrate this stuff into rake autospec that would be mighty cool.
3 إعجابات
Anything that makes testing easier!
It wants to run the tests multiple times which doesn’t make a lot of sense if you’re running a subset via rake on the command line. I included a RETRY flag. I would say the default value should be false but I guess that will break other things.
إعجابَين (2)
I believe @zogstrip took a stab at this and it had many issues. In particular it seemed significantly slower than before.
إعجاب واحد (1)
I believe that’s what @sam is suggesting. Having it integrated nicely would be mighty cool :wink:
3 إعجابات
