I’m looking at extending an existing plugin but it has no tests. I’d rather code to a TDD cycle but I cannot find much documentation on how to build plugins this way.
Here’s an example of a plugin using Grunt as the task runner:
https://github.com/chrisbeach/discourse-plugin-stripe
Of course core uses a rake task which runs phantomjs:
cmd = "phantomjs #{test_path}/run-qunit.js http://localhost:#{port}/qunit"
There’s also Gulp and I am thinking about installing discourse and running my plugins inside of that (as above) but that would be slow…
Is there a convention for running QUnit specs for a plugin on Travis?
