I was Installing the Discourse Dependencies and packages to my system, but I didn’t know that this will require about 7gigs of my hdd. I’m not sure if the installation is successful because in the process I was getting messages about that my computer is running out of space.
My computer has only 1gig free now and I’m not sure If I can continue with the installation locally.
Hi Sam, yeah my computer is blocking me to continue, I’m running Yosemite 10.10.5 and Docker doesn’t support that version anymore. I will make the upgrade of my OS later today and I will let you know if I have any problems. Thank you!
Hello, I’m having problems to install the Bootstrap Discourse, none of the gems (source ~/.bashrc and bundle install) seems to work, what I’m doing wrong? Attached screenshot of where I’m stuck, thank you!
cd ~/discourse
./bin/docker/boot_dev --init
# wait while:
# - dependencies are installed,
# - the database is migrated, and
# - an admin user is created (you'll need to interact with this)
./bin/docker/rails s
Hi Jay, I’m not using Docker to install Discourse for Development, I’m using Terminal and I’m not really sure about what you just mentioned. I’m following the steps and when installing the Bootstrap Discourse doesn’t look that is doing anything, please see screenshot. Thank you
As @sam said, if you just type the commands that I showed you above, you’ll be all set.
Also, do you see where you typed “cd discourge” and not “cd discourse” and you didn’t notice that you typed it wrong and just kept going? If you are not paying enough attention to notice that, or don’t understand what “No such file or directory” means, then you really don’t have much of a chance.
Not to me, though. “You must be a full blown dev to build a simple CSS theme” is madness, in my book
But I guess it is what it is.. this is a project of sheer cliff-face wall barriers to new contributors and has been for a long time. I guess the good news is that people who don’t freeze to death on Kilimanjaro go on to become amazing mountain climbers?
Depends on your perspective. If all you know is basic HTML and CSS it is a huge mountain.
Also, if you want someone to do something, urging them to do it, walking them through the steps, pointing them to how-to guides is fruitless. What you should be asking yourself is why aren’t they already doing what I want them to?
And that’s a much more interesting conversation about barriers to entry.
That is it, all done. The big barrier here is that @EdgarC had low disk space followed by running an old version of Mac OS (Docker supports El Capitan which was released at September 30, 2015)
I completely concede that if you insist on being able to do this on old Macs it can be fairly tricky, but Windows 10 or, less than 2 year old mac it should be fairly straight forward.
hey @notriddle, are you using Windows 10? then you don’t have to worry about virtualization anymore. Discourse development in Windows is very simple now.
I did not continue using Docker because they do not support my current iOS version and as per Sam’s advice, it’s better for me to have Discourse installed locally.
I still have problems on the Bootstrap step, what could it be?
