Discussion revolves around an issue where anonymous users appear in the “Pending Users” queue, even though they don’t require approval. KazWolfe initially reported this as a minor UI issue, and codinghorror acknowledged it as an edge condition that needs to be fixed.
Others, including alxsal and Bas, have experienced similar issues, where anonymous users show up in the review queue despite their posts being visible immediately. sam explained that conceptually, approval should flow through, and the anonymous shadow account should be approved if the master account is approved.
However, Bas pointed out that this issue might be related to a bug where emails report 0 users waiting for approval, but anonymous users are still present in the queue. They believe this is a genuine bug, rather than a feature.
Is there a way to make it so anons don’t appear here? There’s no reason to approve anons and their accounts already work. It just seems excessive and untidy.
Reviving this old topic to indicate I’m having the same issue with (near) latest (v1.7.0.beta7 +27) on an invite-only forum with anonymous posting enabled.
When a registered and approved user creates a post in anonymous mode :
The corresponding post is visible immediately to other users
but an anonymous user appears in Users > Pending
Is this normal behaviour ?
Will I have to approve a different Anonymous user each time a different user writes a post in anonymous mode, or will the same approved Anonymous user be used each time ?
This seems to still be an issue.
Anonymous users are showing up in the review queue for me.
But as Alex says, the posts are showing up as if they are approved users, so it’s mostly a cosmetic issue for now.
Nous recevons des e-mails indiquant qu’il y a 0 utilisateurs en attente d’approbation. Lorsque nous accédons à la file d’attente, les utilisateurs anonymes y sont bien présents.
Je pense vraiment qu’il s’agit d’un Contribute > Bug et non d’une « fonctionnalité, pr-welcome ».
