Homepage-UI geändert, Fehler 422, MESSAGE BUS FAIL
Hello dear,
Any idea why I am getting this error?
Problem Description
  • Homepage UI changed: Please see the users image
  • Padding between two threads
  • Console log says “MESSAGE BUS FAIL”. Ref: screenshot.
Failed to load resource: the server responded with a status of 422 ()
_application-5c2e5fe621d5a6e2f323a3b17b491304c17bd2e3c68992b9568fff4a818180b5.js:10782 Error: [object Object]
    at _application-5c2e5fe621d5a6e2f323a3b17b491304c17bd2e3c68992b9568fff4a818180b5.js:13244
    at A (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:57655)
    at S (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:57670)
    at C (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:57638)
    at _ (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:57573)
    at invokeWithOnError (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12552)
    at a.flush (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12613)
    at u.flush (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12737)
    at p.end (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12807)
    at p.run (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12921)
t @ _application-5c2e5fe621d5a6e2f323a3b17b491304c17bd2e3c68992b9568fff4a818180b5.js:10782
/posts/31789:1 Failed to load resource: the server responded with a status of 422 ()
  • This is happening while navigating from one post to Homepage.
Thanks & Regards,
Gulshan
Can be a rouge plugin! have you tried safe mode?
Ps: Anon view is fine!
I have only these plugins, where ‘discourse-whos-online’ I have disabled already because slow experience. I am noticing just from today few hours ago!
It loads fine to me, I only see those errors because of my adblock no ember errors here.
In my browser, when I noticed this issues there was no any Chrome extentions enabled. In your screenshot, appears normal.
Try visiting https://help.gulshankumar.net/safe-mode in incognito and disable all plugins and themes for safe mode, If the errors still persist, post a screenshot here.
I did browser refresh, issue disappeard. Also, tested in safe-mode, everything is loading fine.
Can be bad cache! … Glad that it’s fixed.
Just to be safe, keep a look at https://help.gulshankumar.net/logs for some hints in case anything terrible is going on.
Again, I am facing. Ref: Video
This is exactly the behavior that I was facing back in the day on your forum if I’m not mistaken.
I couldn’t figure this out as an issue in discourse core because it wasn’t reproducible anywhere else.
Can reproduce it once again! but no ember errors anywhere in my browser.
Also, this happens even in the safe mode. but only on help.gulshankumar.net
@Johani any idea?
