Alguns usuários recebem erros de javascript ao tentar carregar nosso Discourse
I am in the process of moving our self-hosted Discourse from one server to another at a different domain.
I created the new DIscourse using a copy of the original app.yml (but with the domain name changed, and email temporarily disabled). I then backed up the old server and restored it on the new one.
The new server works fine for me, but some of our users who are testing it for me get a partially filled, unresponsive screen.
I have asked one to send me their chrome console log, and it looks like this:
plugin-api.js:19 [PLUGIN discourse-question-answer] To prevent errors in tests, add a `pluginId` key to your `modifyClass` call. This will ensure the modification is only applied once.
be @ plugin-api.js:19
modifyClass @ plugin-api.js:104
p @ qa-edits.js:172
e.withPluginApi @ plugin-api.js:2017
initialize @ qa-edits.js:512
o.initialize @ app.js:41
(anonymous) @ index.js:126
e.each @ dag-map.js:192
e.walk @ dag-map.js:121
e.each @ dag-map.js:66
e.topsort @ dag-map.js:72
_runInitializer @ index.js:138
runInstanceInitializers @ index.js:124
_bootSync @ instance.js:101
didBecomeReady @ application.js:650
p.invoke @ queue.ts:201
p.flush @ queue.ts:98
h.flush @ deferred-action-queues.ts:75
q._end @ index.ts:616
_boundAutorunEnd @ index.ts:257
p @ qa-edits.js:296
p @ qa-edits.js:301
p @ qa-edits.js:309
p @ qa-edits.js:356
p @ qa-edits.js:369
plugin-api.js:19 [PLUGIN retort] To prevent errors in tests, add a `pluginId` key to your `modifyClass` call. This will ensure the modification is only applied once.
(anonymous) @ retort-init.js:52
(anonymous) @ retort-init.js:203
initialize @ retort-init.js:203
(anonymous) @ retort-init.js:73
plugin-api.js:19 [THEME 26 'Categories Boxes Layout'] To prevent errors in tests, add a `pluginId` key to your `modifyClass` call. This will ensure the modification is only applied once.
(anonymous) @ b6863d93ed8f4b85f42f5111df3c50034797d706.js?__ws=forums.extinctionrebellion.uk:29
initialize @ b6863d93ed8f4b85f42f5111df3c50034797d706.js?__ws=forums.extinctionrebellion.uk:26
(anonymous) @ b6863d93ed8f4b85f42f5111df3c50034797d706.js?__ws=forums.extinctionrebellion.uk:40
program.js:103 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'getHelper')
    at u.helper (program.js:103:1)
    at opcode-compiler.js:229:1
    at ne (opcode-compiler.js:2214:1)
    at l (opcode-compiler.js:2149:1)
    at opcode-compiler.js:440:1
    at y.compile (opcode-compiler.js:422:1)
    at x (opcode-compiler.js:629:1)
    at opcode-compiler.js:1933:1
    at te (opcode-compiler.js:2152:1)
    at opcode-compiler.js:2131:1
    at Z.compile (opcode-compiler.js:2114:1)
    at $t.compile (runtime.js:4855:1)
    at Object.evaluate (runtime.js:1981:1)
    at Object.evaluate (runtime.js:1052:1)
    at It.evaluateSyscall (runtime.js:4263:1)
    at It.evaluateInner (runtime.js:4234:1)
    at It.evaluateOuter (runtime.js:4227:1)
    at $t.next (runtime.js:5058:1)
    at $t._execute (runtime.js:5045:1)
    at $t.execute (runtime.js:5038:1)
    at Qt.sync (runtime.js:5105:1)
    at Or.render (index.js:6757:1)
    at index.js:7021:1
    at Mt (runtime.js:4139:1)
    at Sr._renderRoots (index.js:7004:1)
    at Sr._renderRootsTransaction (index.js:7047:1)
    at Sr._renderRoot (index.js:6993:1)
    at Sr._appendDefinition (index.js:6919:1)
    at Sr.appendOutletView (index.js:6907:1)
    at p.invoke (queue.ts:203:14)
    at p.flush (queue.ts:98:13)
    at h.flush (deferred-action-queues.ts:75:19)
    at q._end (index.ts:616:32)
    at _boundAutorunEnd (index.ts:257:12)
helper @ program.js:103
(anonymous) @ opcode-compiler.js:229
ne @ opcode-compiler.js:2214
l @ opcode-compiler.js:2149
(anonymous) @ opcode-compiler.js:440
compile @ opcode-compiler.js:422
x @ opcode-compiler.js:629
(anonymous) @ opcode-compiler.js:1933
te @ opcode-compiler.js:2152
(anonymous) @ opcode-compiler.js:2131
compile @ opcode-compiler.js:2114
compile @ runtime.js:4855
(anonymous) @ runtime.js:1981
evaluate @ runtime.js:1052
evaluateSyscall @ runtime.js:4263
evaluateInner @ runtime.js:4234
evaluateOuter @ runtime.js:4227
next @ runtime.js:5058
_execute @ runtime.js:5045
execute @ runtime.js:5038
sync @ runtime.js:5105
Or.render @ index.js:6757
(anonymous) @ index.js:7021
Mt @ runtime.js:4139
_renderRoots @ index.js:7004
_renderRootsTransaction @ index.js:7047
_renderRoot @ index.js:6993
_appendDefinition @ index.js:6919
appendOutletView @ index.js:6907
p.invoke @ queue.ts:203
runtime.js:1051 Uncaught TypeError: Cannot read properties of null (reading 'syscall')
    at Object.evaluate (runtime.js:1051:1)
    at index.js:7021:1
    at Sr._revalidate (index.js:7080:1)
    at p.invoke (queue.ts:201:14)
    at q.end (index.ts:298:10)
    at q._run (index.ts:667:14)
    at q._join (index.ts:640:19)
    at q.join (index.ts:362:17)
    at p (index.js:157:1)
    at index.js:258:1
evaluate @ runtime.js:1051
_revalidate @ index.js:7080
q.end @ index.ts:298
q._run @ index.ts:667
q._join @ index.ts:640
q.join @ index.ts:362
p @ index.js:157
(anonymous) @ index.js:258
How do I go about debugging and fixing this issue, please?
O discourse-question-answer é um plugin obsoleto. Ele foi substituído pelo discourse-post-voting.
Remova o antigo do seu app.yml e, se você o estava usando, substitua-o pelo novo. Em seguida, reconstrua.
8 curtidas
