Yes. If you want us to look after things for you then you can see our options here. If you sign up for a trial we can talk you through configuring the CNAME record.
There are also third party hosts with slightly different offerings.
yes, I could get a .org domain and use that for running discourse. But a random .org doesn’t have the built-in credibility of an .edu (at least not for research purposes)
I will sign up for sure. In the U.S. it is Thanksgiving. And I just feel a bit guilty being online (essentially working). I may sneak back later and get the signup done. Thanks for your help.
You can definitely use the .edu domain. In the first instance you can set up your trial on our trydiscourse.com domain (you’ll be given that option when you sign up) and then we can help you work out the best way to configure things so that it’s intuitive for your users.
Check with your building or college tech person & they’ll know who contact to get that stuff worked out. If I were still at Stanford, I’d run Discourse on a server in the closet down the hall, but that’s just me.
