Are they created following a simple arithmetic pattern? Also, are they based for the entirety of an instance, or only personal accounts? I’m using the API and seeing some inconsistencies.
It’s a PostgreSQL sequence. It increases +1 for every new topic.
Thanks for the quick response! Are they unique values across the entire Discourse instance or are they based on each individual user?
They’re unique across the whole instance.
