איך אפשר לשנות את הטקסט בתיאור לבלתי מסווג
How can I check the text inside the green box? This is the default uncategory.
I have tried to delete this category with no success.
Screenshot below shows all catagories I have currently,
I can change the description text for other category at category setting (see below)
But for this default uncategory there is no such setting to change the description text.
Now I have totally forget where did I set those text for uncategoty topics.
I believe it’s on the site settings.
I think you need to go to Admin -> Customize -> Text content and search for category.uncategorized_description.
