skozz
(Raúl M.)
#1
Hi again, before of all sorry if this issue is duplicated, I searched before post my doubt without success.
In our forum we need to set some post just below of the first post. Like a “pinned” posts inside the topic.
[First post of a topic]
[Posts “pinned” inside the topic]
[Rest of posts]
Exists someway to make this? Thanks.
There is no way to pin replies. I suggest adding a first reply and editing it to taste, or editing the bottom of the first post.
Falco
(Falco)
#3
IF (big if) you want to pin the “solution” to the topic, the solved plugin creates a nice link on the OP.
skozz
(Raúl M.)
#4
Thank you for you reply Jeff. I’ll consider it
@Falco, is insufficient for me, but thank you too!
Another new way to do this, sort of, is a post notice. Use the wrench menu on a post to add it.
