How do I calculate the token usage of every user in Discourse AI?
i am using official discourse ai plugin with openai api key
Is there any way to calculate the token usage of every user?
-- [params]
-- date :start_date
-- date :end_date
WITH token_usage AS (
    SELECT
        user_id,
        SUM(request_tokens) AS total_request_tokens,
        SUM(response_tokens) AS total_response_tokens,
        SUM(request_tokens + response_tokens) AS total_tokens
    FROM
        ai_api_audit_logs
    WHERE
        created_at BETWEEN :start_date AND :end_date
    GROUP BY
        user_id
SELECT
    u.id user_id,
    tu.total_request_tokens,
    tu.total_response_tokens,
    tu.total_tokens
FROM
    token_usage tu
JOIN
    users u ON u.id = tu.user_id
ORDER BY
    tu.total_tokens DESC
Will show top usage per user for date range.
It shows users who aren’t using anykind AI at all. Any ideas why, included in summaries or something?
Maybe, look at the logs, filter on user it will tell you which feature it is
SqlHelper persona can help you with the query
thanks for your reply, could you please explain more about how to run these code?
should i execute them after ./launcher enter app?
how to change start_date and end_date?
what’s the type of these code? i just know some python
Sorry for my ignorance :pensive:
Hi @whitewaterdeu, that SQL query Sam posted can be run from the admin UI using the data explorer plugin.
