Hoe wijzig ik de volgorde van categorieën?
I’d like some categories show on the top or in certain orders.
Thank you for the quick reply!
I can’t find the setting for the enabling the fixed category position, I can’t find ‘create’ menu item.
what am I doing wrong?
Found it… man … difficult…
Where did you find it?
The fixed category positions and fixed category positions on create are in the admin settings. Searching the settings for ‘fixed’ will bring both up:
[YourSite]/admin/site_settings/category/all_results?filter=Fixed
And then the wrench icon on the category view will have the extra option in to reorder the categories:
But the link @Moin gave above goes into more detail. :+1:
Thank you! That helped a lot! :slight_smile:
