snakeninny is seeking help to migrate legacy CDN image URLs (e.g., http://7xibfi.com1.z0.glb.clouddn.com/) to a new custom CDN (http://cdn.iosre.com/) across all posts on their Discourse forum. They’ve already updated DISCOURSE_CDN_URL in app.yml and rebuilt, but legacy URLs persist. itsbhanusharma suggests using the rake find-and-replace task, which snakeninny tries successfully for 44 posts, but discovers legacy URLs still appear in database files and CSS, unaffected by rake. pfaffman and itsbhanusharma recommend rebaking posts via rake posts:rebake, which snakeninny runs — resulting in images now pointing to the forum’s own domain (iosre.com) instead of the intended CDN (cdn.iosre.com). The core issue remains: how to ensure all legacy image URLs are rewritten to use the new CDN host, not the local domain. itsbhanusharma questions whether the S3 CDN URL setting might be involved, and pfaffman confirms that rebaking is the correct step after updating CDN settings. The solution likely involves ensuring the CDN URL is correctly set and rebaked across all posts, possibly requiring deeper inspection of upload URL configuration or custom script intervention for non-post files.
Forgive me if there’re duplicate topics but I don’t even know what keywords to search, so I started a new topic describing my problem.
Recently I got update from my CDN provider that they will abandon the legacy URLs like http://7xibfi.com1.z0.glb.clouddn.com/, and suggested me to change the URLs to my custom one http://cdn.iosre.com/ ASAP.
The problem is that most of the old posts on my website, e.g. this one, contains images with the legacy URLs, and they will be not accessible after the CDN provider abandon them.
I have already changed the CDN URL in app.yml and rebuilt discourse, but the legacy URLs will not be affected, right?
Seems the link is what I’m looking for; I will try it once the backup is done. Thanks for the info!
I have tried rake and 44 posts were remapped. But I see another situation in my post, the source of the post looks like <img src="/uploads/default/213/acc63bd2c2d03f28.png" width="496" height="138"> but for readers who don’t have access to the post source and if they copy the image address, it turns out to be http://7xibfi.com1.z0.glb.clouddn.com/uploads/default/213/acc63bd2c2d03f28.png.
And I have tried to grep -r 7xibfi.com1.z0.glb.clouddn.com /var/discourse, turns out this URL appears in databases such as /var/discourse/shared/standalone/postgres_data/base/16400/361518 and css files such as /var/discourse/shared/standalone/uploads/stylesheet-cache/mobile_51397cef7eb3aa4cc8e1939c4ef7156c29bfc9e2.css, and rake doesn’t work on these files.
Any other ideas how can I change all legacy CDN URLs?
Can you confirm in your admin area if the s3 cdn url is blank or has any value set ?
@zogstrip some time ago there was some issue surrounding the upload urls which had brought me into a very similar situation! I remember you fixed it but can this be related to that?
Did you rebuild after you changed the value? (Enable a CDN for your Discourse, which is linked to in the yml file you edited says to rebuild after the change.)
EDIT: after a whole night, http://iosre.com/uploads/default/original/1X/735abc46bddabe584790cf2218d5d9bbc1f2501a.png becomes http://cdn.iosre.com/uploads/default/original/1X/735abc46bddabe584790cf2218d5d9bbc1f2501a.png, so I guess it takes a while processing all URLs? I am checking more posts to double confirm.
I did rebuild after changing DISCOURSE_CDN_URL in app.yml.
I tried running rake posts:rebake, now all images with legacy URLs such as http://7xibfi.com1.z0.glb.clouddn.com/uploads/default/original/1X/735abc46bddabe584790cf2218d5d9bbc1f2501a.png become http://iosre.com/uploads/default/original/1X/735abc46bddabe584790cf2218d5d9bbc1f2501a.png, which is hosted right on the server instead of on the CDN.
What can I do to use new CDN host cdn.iosre.com for all legacy URLs?
