Comment trouver un développeur pour aider avec wp-discourse ?
Hi,
I Have a couple of issues with the Discourse-Wordpress integration (First, comments don’t appear on wordpress. Second, posts fail to auto-publish to Discourse).
I would like to hire a developer to help me with these issues (and more) but it is very hard to find a wordpress developer that also knows Ruby on rails (which as I understand is the what Discourse is using).
The question is, given that I can’t find a programmer for both Wordpress and Discourse - what is the most important skill? Wordpress or Ruby?
If you would like to hire a developer to help with discourse and WordPress, post the requirements and your budget in the Marketplace.
You’re describing issues that require discourse expertise. Many discourse folks are familiar with WordPress.
