How do I put an image in my bio?
How can I put an image in my Discourse bio, it also just shows up as the links image.
Hi Stache as far as I know, this isn’t possible. You can add images to your profile however, via the ‘profile header’ and ‘usercard background’.
Nevermind, I figured it out.
If you go to a conversation (let’s say with discobot) and post the image, then go to edit and copy that link, you can paste that link and it’ll show up!
Edit: It only shows after you click on the bio, but from the 2 lines beforehand, it shows the link
I wish it was more simple to add images, I wonder why it isnt?
