도와주세요 여러분
플러그인에서 검증기(validator)를 어떻게 사용해야 하나요?
플러그인에 파일을 추가했습니다
lib/validators/plugin_ldap_setting_validator.rb
settings.yml에서 사용
forum_ldap_validation:
default: 'system'
validator: 'PluginLdapSettingValidator'
plugin.rb에서 파일 로드
load File.expand_path('../lib/validators/plugin_ldap_setting_validator.rb', __FILE__)
에러가 발생합니다
! Unable to load application: NoMethodError: undefined method `lazy' for nil:NilClass
bundler: failed to load command: puma (/home/smart/.rbenv/versions/2.6.5/bin/puma)
/home/smart/discourse/lib/plugin_initialization_guard.rb:9:in `rescue in plugin_initialization_guard'
/home/smart/discourse/lib/plugin_initialization_guard.rb:3:in `plugin_initialization_guard'
/home/smart/discourse/config/application.rb:269:in `<class:Application>'
/home/smart/discourse/config/application.rb:59:in `<module:Discourse>'
/home/smart/discourse/config/application.rb:58:in `<top (required)>'
/home/smart/discourse/config/environment.rb:4:in `require'
/home/smart/discourse/config/environment.rb:4:in `<top (required)>'
config.ru:6:in `require'
config.ru:6:in `block in <main>'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/rack-2.0.8/lib/rack/builder.rb:55:in `instance_eval'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/rack-2.0.8/lib/rack/builder.rb:55:in `initialize'
config.ru:in `new'
config.ru:in `<main>'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/rack-2.0.8/lib/rack/builder.rb:49:in `eval'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/rack-2.0.8/lib/rack/builder.rb:49:in `new_from_string'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/rack-2.0.8/lib/rack/builder.rb:40:in `parse_file'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/puma-4.3.1/lib/puma/configuration.rb:321:in `load_rackup'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/puma-4.3.1/lib/puma/configuration.rb:246:in `app'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/puma-4.3.1/lib/puma/runner.rb:155:in `load_and_bind'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/puma-4.3.1/lib/puma/single.rb:98:in `run'
/home/smart/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/puma-4.3.1/lib/puma/launcher.rb:172:in `run'
