Como encontrar o ID das tags para adicioná-las ao criar um tópico via API
I wanna create topic via API
How find tags id to add tags when create topic via API
Thank!
AFAIK you don’t need tag ids. You can just pass the tag names.
3 curtidas
Does anyone know if this should work in 2.0.0.beta9? Tags are not mentioned in the API docs for POST /posts.
I tried to create topics with tags="testtag" but got a HTTP 500 error.
From the logs:
NoMethodError (undefined method `-' for "testtag":String)
/var/www/discourse/lib/discourse_tagging.rb:220:in `tags_for_saving'
You should try like tags[]="testtag". It’s an array type.
3 curtidas
It’s not working. Is there a way to add tags?
1 curtida
this is not working, my call looks like,
$body = '{
            "async": false,
            "title": "'.$word.'",
            "raw": "'.$definition.'",
            "category":'.$categoryId.',
            "topic_id": '.$topicsId.',
            "tags[]": "test-tag"
it creates the topic but it doesnt create or add the tag with the new topic. @vinothkannans
