Please see the screenshot. Functionally it is working if I drag the create window up to the top. However from UX perspective, I need to resolve this. Any suggestions on how to handle a really long create form?
Are you using your own plugin or a existing one? Or is this the form-templates feature?
1 curtida
My own custom plugin.
1 curtida
Is the repo public?
(you are more likely to get help with problems if your plugin is more widely adopted as then others will face the same issue)
2 curtidas
Thank you! I will surely consider that once I am comfortable with what I am doing.
1 curtida
