Handling Discourse after installation can be manageable even for non-coders. riteshsaini asked about the difficulty level of maintaining a Discourse installation on DigitalOcean, and pfaffman and marianord provided reassurance that it’s possible to keep Discourse running smoothly with minimal technical expertise.
To ensure a secure setup, it’s recommended to:
Set up automatic security updates
Configure backups to S3
Perform command line upgrades and rebuilds periodically
Consider using a firewall to block all ports
DigitalOcean’s default security settings provide a solid foundation, and users can opt for additional technical setup or support from experienced installers if desired. However, some upgrades may require more technical expertise, such as updating the PostgreSQL database.
I want to install Discourse on DigitalOcean. I’ve checked this guide. Now my question is that, how hard is it to handle Discourse after the installation? I’m not a coder and don’t know how to handle servers.
So, is the basic installation enough? Or do I need to take care of server security hardening or anything else?
I’ve had a bunch of clients for whom I’ve done and installation and they have done absolutely nothing for years, not that I recommend it. If you set up automatic security updates and a few times a year do s command line upgrade you’ll likely be fine. I offer a service to do command line rebuilds automatically when they are required.
If you want to be a bit safer you can configure pushing backups to S3, so if something does happen to the server you’ll have a backup.
Discourse is a pretty solid software and if you can install the forum by your own you can keep it running smooth. Just going to example.com/admin/upgrade every time you get an email or the notification in the Admin Dashboard and something like twice a year entering into the server and doing ./launcher app rebuild.
DigitalOcean keeps the servers pretty secure by default, if you want it to be even more secure you can get a firewall to block all the ports.
You can talk with any of the guys that offer an installation of Discourse here so they can get it set up for you (if you prefer) with a more technical initial setup.
A few times a year, a command line rebuild is required to update the base container. And every couple years a more complicated upgrade like PostgreSQL 12 update happens, which though well documented, can be a bit hairy for someone unfamiliar with the command line. But as I said, I don’t recommend it, but I’ve seen people go years doing nothing whatsoever!
