I have been running my discourse forum on Digital Ocean for a few months. Works beautifully at $10 a month. I know DO is an unmanaged VPS, so I am wondering what maintenance task is required?
If maintenance tasks are required, what happen if I leave the server alone? This is a fairly small forum, just wondering if i need a system admin. If i do, it might make more sense to go with Communiteq (formerly DiscourseHosting).
Setting up unattended upgrades and occasionally (every few months) running
cd /var/discourse
./launcher rebuild app
(in addition to regular web-based upgrades) should be enough for quite some time. When the disk gets full, run
sudo apt-get autoremove
sudo apt-get clean
cd /var/discourse
./launcher cleanup
to free up some space. When the support for your version of Ubuntu runs out, it’s probably easiest to take a backup and restore on a new droplet (using the same app.yml file).
In short: Some maintenance is required (and neglecting that will pose security risks), but it’s neither hard nor a lot to do. And if you run into problems, we’d be happy to help
I am also running a small community on Digitalocean. It has been running like a top (knock on wood) for almost a year now, and I have done nothing but perform Discourse upgrades via the web interface.
Never really thought about Ubuntu upgrades, etc. Maybe I should, but I am no sys admin…
But if you want to be in the safe side (which is always a good idea), begin by taking and downloading a backup, and store a copy of app.yml. If anything goes sideways and you cannot fix it, it takes less than 60 minutes to reimage and restore your droplet
A way to practice installing, restoring, and modifying Discourse.
A non production environment to test changes on.
If you run it with mail enabled you can get user feedback about new features.
If you use a different provider for your VPS, but the same OS, with the same updates, and your discourse installation has the same plugins, permissions, groups, settings (Except for site name, notification email), and update level, then if something stops working on your live site, but still works on your sandbox, then you’ve already narrowed down the list of possible causes by a large factor.
Best I can tell, the difference between -phigh and -plow is that the former doesn’t ask you any questions.
If you’re someone who’s not likely to log in to your server, you really need to reboot it without your having to log in if security updates require a reboot. The time is in UDT, 9:00 is 5AM EST and 2AM PST (and I guess it might be an hour different from that now). A reboot takes just a minute or two. The 40 or so people for whom I left the reboot time at 2:00, haven’t complained.
If you want an occasional sysadmin to intervene in some emergency or do a check-up, or want someone to pay attention to upgrades and such I am available as are others if you post in #marketplace.
I must respectfully disagree. Without making a drama, if you do not make security updates for weeks or months, you will get hacked. It’s that simple. There are occasional kernel exploits that do not even require open services. In order to protect the data, such as the e-mail address of the users, a maintained system is essential.
Depending on the country in which you live, you can be held responsible for any damage caused. For example, if spam is sent via the hacked server, or a DDOS attack is executed, it becomes expensive.
I know I am rather alone with this opinion. But a server with large bandwidth is like a internet weapon. You have to know what you are doing or you let others do it.
To add some more confidence to that solution: I’ve been running multiple servers with this exact setup for quite some time, without any problems.
One side effect of the way that unattended-upgrades works is that this will not update Docker – I’ve added "Docker:ubuntu-xenial" to Unattended-Upgrade::Allowed-Origins to fix this (and also uncommented "${distro_id}:${distro_codename}-updates" to get non-security updates). Automatic updates for Docker will cause about one minute of downtime when they are installed (at an unpredictable time), so this may not be suitable for everyone
I don’t think so, because the origin shouldn’t match – this is because Docker doesn’t come out of Ubuntu’s repository and uses a different origin.
I’m no expert here, though, so feel free to correct me. I can confirm that non-security-updates will not be installed automatically even if "${distro_id}:${distro_codename}-updates" has been uncommented.
(unattended-upgrades -d is your friend if you want to play around with this.)
Hello, pls tell me what is the real minimum requirent for install discourse ?
I wanna start comunity for 300 users per day. Im not sure , discourse will be good on my server with 1gb ram ? 1 core, and 10 gb ? Do i need ssd disk or not really ?
Find something a bit more powerful if You want less pains in life managing a forum server!
I’d suggest a bare minimum of 2Cores and at least 2 GB RAM when You set up the forum for 300 Users you also have to bother about the images and stuffs they post so for the foreseeable time and estimation of their behaviour I’d suggest something like a 40GB SSD on Which You can actually set up vswap in case You’re blowing up your system RAM.
Oh thanks for info but wait , im not sure im understand You .
I must set any partition or somethink or just i need to take only server with 40gb ssd and clean os ? I can set this partition after instalation discourse or before ? Btw Ubuntu will be the better than centos / debian ?
