Or is there any url I can browse to see this?
Thanks!
adding ?order=createdate should do it (at least it seems to work here)
I think that doesnt work
What URL did you try? and what version of Discourse are you running?
Oops. You’re right - seems to be synonymous with activity
Is there one url to see this actually?
Go into your admin area - it’ll tell you right on the top left what version you’re using.
I am using latest 1.3 beta2
You want latest?order=created
I was close
