Hoe voeg ik een Leaderboard-link toe aan het hamburger-menu?
The discussion revolves around adding a Leaderboard link to the hamburger menu in Discourse using the Gamification plugin. Bitweb_Core asks how to make the leaderboard visible to users and where to find it in the menu after enabling the plugin. isaac directs them to the plugin settings at /admin/plugins/gamification and explains that there is no public link by default. Bitweb_Core also inquires about purging and reusing leaderboard IDs, to which isaac clarifies that IDs cannot be reset and will increment automatically. JammyDodger suggests using the custom hamburger menu links theme component to add a public link to the leaderboard in the menu.
I have a question about Solver plugin and Leaderboard plugin
about how to add stats to user stats and badges
about the Leaderboard, how to make it visible to users, where is it in the menu, if i need self add it , where i can do that ?
what i need to-do for make visible to users /leaderboard
or i need some how add it to menu ? if yes , how ?
I would recommend following the
:open_book: Install Guide How to install plugins in Discourse
Then
For per leaderboard permission settings you can visit /admin/plugins/gamification
where it put /leaderboard?
how i can find it from user side at menu ? button what go to it after enable.
or i need self create it ? but where and how .
Like this
and maybe another qustion , how i can purge
leaderboarts/1
leaderboarts/2
leaderboarts/3
if it was deleted , and recreated.
Links to leaderboards are available at /admin/plugins/gamification. This is obviously only available to admins, and there is no public link by default.
As you pointed out here, you would need to build it yourself or reach out to someone at Marketplace
There is not an option to reset or reuse leaderboard ids, it will always increment by 1.
You can use the Custom Hamburger Menu Links theme component to add a link to each leaderboard to your hamburger menu. :+1:
