Come aggiungere un'azione per un pulsante in un plugin
I want to make a plugin to show a button and do some action. The button can already be displayed at the desired place, but I don’t know how to create a custom action for it. The file structure is like followings:
plugins/discourse-my-plugin
├── assets
│   ├── javascripts
│   │   └── discourse
│   │       ├── initializers
│   │       │   └── my-plugin.js.es6
│   │       └── templates
│   │           └── connectors
│   │               └── user-messages-nav
│   │                   ├── actions.js.es6
│   │                   └── button.hbs
├── config
└── plugin.rb
initializers/my-plugin.js.es6
import { withPluginApi } from "discourse/lib/plugin-api";
function initializeButton(api) {
  api.decoratePluginOutlet('user-messages-nav', (elem, args) => {
export default {
  initialize() {
    withPluginApi("0.8.31", initializeButton);
button.hbs
{{d-button class="btn-primary" action="submitContent" label="submit_content"}}
Is it correct to create my custom action like this in actions.js.es6? The error is “had no action handler for: submitContent” but how can I fix it?
export default {
  actions: {
    submitContent() {
2 Mi Piace
You were very close :+1:
You only need to change the file name. Both the .hbs and js.es6 files in your connector class need to have the same name. So, if you change
actions.js.es6
to
button.js.es6
it should work. You can read more about connector classes here
7 Mi Piace
Thanks Joe, it works like a charm!
3 Mi Piace
