How to add auto-ads between messages
Hello!
I will try to explain myself as best as possible with Google Translator :stuck_out_tongue:
I need to insert banners and ads between forum messages, randomly. It is not for adsense or other known ads. It’s ads for adults.
Is there a plugin to do this? Can I do it manually in some way?
Thanks!!
If you want to insert ads other than what the ad plugin supports, you will need to develop a plugin or theme component to do that.
Ouch! Okey, thank you.
