I wonder if there’s a way to increase the space between paragraphs.
In the editor, even If I separate each line with more than one paragraph, in the post there’s only one line of blank space separating them.
The only way of doing this…
[color=#fffff].[/color]
Is using dots and coloring them of white with a plugin.
Hi David,
a minor comment from my side, I used the mardown you suggested on my platform and I noticed some weird behaviour for me. I’m not sure this is a bug, or only a limitation of commonmark?
When the last backslash isn’t followed by regular text in the line right after, the last backslash \ is shown instead of a rendered empty line. (see example below)
It happens when the last backslash…
…is followed by an empty line (or a line with two empty spaces) before subsequent text starts
subsequent text
…is followed by blockquotes
text in a blockquote
It doesn’t happen when followed by regular text
regular text
Here's the text/code I used
It happens when the last backslash...
...is followed by an empty line (or a line with two empty spaces) before subsequent text starts
subsequent text
...is followed by blockquotes
> text
It doesn't happen when followed by regular text
regular text
