The discussion addresses an issue with list formatting in Discourse when an empty line separates two lists, causing rendering problems. JP_ reports that mixing tight and loose list spacing in Markdown leads to formatting errors. codinghorror explains this is due to Markdown’s rules for list spacing, referencing Babelmark for testing. cpradio shares that CommonMark handles this better, while Mittineague suggests using <br> or a horizontal rule as workarounds, though these have limitations. elberet notes that some workarounds still result in a single unordered list. JP_ mentions that tools like Pandoc handle the issue correctly. sam states the issue is resolved with the new Markdown implementation.
You generally cannot mix loose and tight spacing of lists in Markdown. Either the list is tight (no spaces) or loose (always spaces). Mixing the two within the same list will result in strangeness.
