How to change a Post-Created Webhook Event Payload
Hello.
I want to customize the payload value of webbook when an event for topic generation occurs.
Example…
AS-IS
  "post": {
    "id": 19,
    "name": "user",
    "username": "user",
    "avatar_template": "/letter_avatar_proxy/v2/letter/u/c0e974/{size}.png",
    "created_at": "2018-07-20T06:24:33.205Z",
    "cooked": "<p>Cool, now i have you, haha</p>",
    "post_number": 6,
    "post_type": 1,
    "updated_at": "2018-07-20T06:24:33.205Z",
    "reply_count": 0,
    "reply_to_post_number": null,
    "quote_count": 0,
    "avg_time": null,
    "incoming_link_count": 0,
    "reads": 0,
    "score": 0,
    "topic_id": 11,
    "topic_slug": "this-is-new-topic",
    "topic_title": "This is new topic",
    "display_username": "user",
    "primary_group_name": null,
    "version": 1,
    "user_title": null,
    "moderator": false,
    "admin": true,
    "staff": true,
    "user_id": 1,
    "hidden": false,
    "trust_level": 1,
    "deleted_at": null,
    "user_deleted": false,
    "edit_reason": null,
    "wiki": false,
    "topic_posts_count": 6
TO-BE
Can I know how to do it?
I have a similar need. I also feel confused. There is no good solution at the moment.
Hey, there’s no built-in way in Discourse to send only a tiny part of the webhook payload, but a couple of ideas that might work:
- You could have a small proxy in the middle (like a tiny Node.js or Python endpoint) that gets the full webhook, strips everything except `topic_title`, then forwards it on. Super flexible and doesn’t touch Discourse itself.
- Or, if you’re up for it, a tiny Discourse plugin could listen to `on(:post_created)` and send only the fields you care about. Just a few lines in Ruby and you’re done.
- Another lazy option is to just let a tool like Zapier or n8n grab the full payload and map/filter it before it reaches your final system.
Nothing fancy, just some ways I’d play around if I needed only `topic_title` :slightly_smiling_face:
Yes. I am using the first one, but this requires extra coding and maintenance.
