Webhook for Discourse events
סיכום מבוסס בינה מלאכותית
Webhook for Discourse Events Discussion Summary
The discussion revolves around implementing a webhook feature in Discourse, allowing admins to manage webhooks and receive notifications for various events. The proposed specs include:
  • A single page for admins to manage webhooks
  • Payload URL for receiving event notifications
  • Optional selection of individual events to receive notifications for
  • Activation and deactivation of webhooks
  • Logs for POST requests and responses
Suggested events for the webhook include user registration, topic creation, post likes, flag raisings, and more. The discussion also touches on the format of the payload, with two proposed sections: a generic section with timestamp and action, and a specific section with fields relevant to the event.
Proposed Payload Fields
  • User: username, email, name, trust_level, etc.
  • Topic: ID, title, content, creator_username, etc.
  • Post: post_ID, topic_ID, username, content, etc.
Additional Suggestions
Progress Update
  • tgxworld is working on the specs for the project
  • adrapereira is writing a proposal for the project
  • fantasticfears has made progress on the implementation
  • erlend_sh has completed a guide on setting up webhooks
I’m writing up the specs for this in order to facilitate GSoC 2016 application
Specs
  1. A single page at “/admin/webhook” for admins to manage their webhooks
  2. Admins will need to provide a Payload URL which the webhook service will POST the event payload to.
  3. Webhook will POST all events to the Payload URL by default. We should allow admins to select individual events which they require.
  4. A Webhook can be activated and deactivated.
  5. Logs of the POST request as well as the response should be kept and made visible for admins.
For a start, I think the following events suggested by @phanimahesh is pretty reasonable.
19 לייקים
I would love to see this in action! It’s been something I’ve wanted in Discourse for years now.
3 לייקים
Are you saying that forum users will be able to subscribe to one or more published events? Or am I misunderstanding this?
לייק 1
Renamed users to admins.
לייק 1
Thanks :smile:
Now I need to go away and redigest this again. Sounds great tho’
We use a webhooks plugin for our slack integration over at Loomio, which seems like it might be a nice reference for someone looking to implement this.
https://github.com/loomio/loomio_webhooks
5 לייקים
I’m writing a proposal for this project to apply for GSOC 16 and would like your help since I’m not completely familiarized with Discourse and its code.
The settings page will be close the one GitHub has, admins will be able to create webhooks by defining the payload URL and the events that trigger the webhook. After a webhook is created, there will be options to enable/disable, edit or remove it.
I’m thinking that each payload will have two sections: the first defines the payload with some fields like the timestamp and action that triggered the event; the second section contains the fields specific to each action.
Regarding the second section, we can use the existing serializers for the object(s) in question (user, topic, post, etc.) or we can choose carefully which fields will be sent.
Just to start the discussion, I’ve made a quick list of the proposed fields of each payload:
User
user_registered and user_activated
trust_level_changed
username, old_trust_level, new_trust_level
message_sent
sender_username, receiver_username, msg_title, msg_content
Do we want the message content to be sent?
Another option is to define the required information of a user and use it whenever we’re referring to a user. For example, instead of sender_username we would have sender_info which has {ID, name, username, email, trust_level, …}.
Topic
Topic_created
ID, title, content, creator_username, categories
Topic_liked
ID, title, username, number_of_likes
Topic_{pinned,unpinned,archived,closed,invisibled,bookmarked}
ID, title, username
Post
Post_liked
post_ID, topic_ID, username, number_of_likes
Reply_posted
Other
Auto_close_set
I don’t know what this one means…
Flag_raised
post_id, topic_id, reason
This is what I had in mind, please let me know if you had another idea :wink:
10 לייקים
I’d like to add:
Badge Awarded
2 לייקים
Could something like this be used for SES / email bounce webhooks too?
No, those Web hooks are from discourse to outside world. You want the opposite.
There are already bounces webhooks on core for three different providers, tough. Maybe try to craft a PR for ses?
Got it. Thanks. Still trying to figure out the terminology and where bits and pieces of the code are. :slight_smile:
Right now it is easier for me to do it externally in PHP/SQL. PR - One of these days…
לייק 1
By the way, @fantasticfears has been working on getting webhooks in as part of GSOC :slight_smile:
The progress can be found at https://github.com/discourse/discourse/tree/gsoc_webhooks
7 לייקים
Completed:
2 לייקים
