How to change notification level icons?
סיכום מבוסס בינה מלאכותית
Users discuss changing notification level icons in Discourse. meglio suggests replacing the circle icon with a loudspeaker for better visibility. Tom_Newsom provides CSS code to change the tracking icon to a bell (f0a1) and the watching icon to an envelope (f003). watchmanmonitor implements this, using an envelope for watching and a chat bubble for tracking, and asks about adding a blue circle around the envelope. Mittineague explains how to create stacked icons using Font Awesome, showing how to overlay a circle on the envelope. watchmanmonitor then shares the syntax for using a circle-thin icon. dax points to a guide on changing icons globally via APIs.
Is there a way to change tracking icons?
I’d like to try using loud-speaker as a base for all 4 icons. The circle makes little sense and I notice that my users never click there and don’t know what is that for. I think a different icon would bring their attention.
I’d be tempted to put a picture of a letter on Watching, since that’s what we use to indicate “yes, you’ll get emailed on this category/topic”
now that I think about it… there’s nothing really alarming to indicate a ! in the first place.
Add this to your custom CSS:
.icon.fa.fa-circle.tracking::before {
    content: "\f0a1";
That’s just the icon though. You could add a color, background color and radius to make a circle if you’re feeling fancy.
And so for the envelope I want, I’ll use f003
I see that these can be looked up on FontAwesome:
http://fortawesome.github.io/Font-Awesome/icon/envelope-o/
and snag the Unicode identifier.
Thanks so much @Tom_Newsom
So, my completed set is:
content: "\f075";
content: "\f075";
.icon.fa.fa-exclamation-circle.watching::before {
content: "\f003";
content: "\f003";
This leaves me with envelopes for topics which will get you emailed (watching), and a chat bubble for topics which will just notify you (tracking).
I don’t know how to put a blue circle around the envelope, but I think this is a great improvement over the Exclamation point.
It’s called “stacking”
http://fortawesome.github.io/Font-Awesome/examples/
<span class="fa-stack">
  <i class="fa fa-envelope fa-stack-1x"></i>
  <i class="fa fa-circle-o fa-stack-2x"></i>
</span>
Wow, font awesome really is, well, awesome :smile:
Could anyone indulge me with the syntax of getting a stacked icon to instead of the normal icon?
Circle-thin is a thing in Font-Awesome 4.1, and I’d love to put that around all the iconf for uniformity.
  <i class="fa fa-circle-thin fa-stack-2x"></i>
</span>
Changing an icon globally is very simple using APIs
