How to change the styles of CTA buttons of email templates
The email template used to notify about new topics have two “Visit Topic” links that I would like to adjust a little bit. Is there a way of changing the styles of both links?
I wanted to make them both with blue background color and add some padding.
I tried adding CSS by selecting the HTML tags but it does not work. I used the correct selectors (I tested in the browser), but it seems that when the email is generated all styles I added are disregarded.
I tried adding a ‘style’ tag directly into the base template HTML and also tried to using the CSS tab, both ways did not work
Is there an easy way of changing the styles of that elements?
