How to create post with ruby api?
Hello,
Can somebody tell me how to create post with ruby api?
It seems that there is only create topic api in discourse_api gem (GitHub - discourse/discourse_api: Ruby API for Discourse).
Check out the source code:
discourse_api/lib/discourse_api/api/posts.rb at main · discourse/discourse_api · GitHub
I’d assume create_post is what you’re looking for, but I’m not a Ruby expert.
Thanks, it just works!
Better if I can get the latest inserted topic_id when I call create_topic method. I’ll have a try!
