The user @xebiyen wants to reset their Discourse forum by deleting all content—topics, images, and media—while retaining only the users. They are concerned about server space, copyright issues, and the complexity of the process. The community suggests multiple approaches: using the ./launcher cleanup command, manually deleting data via Rails console commands like Topic.destroy_all and Upload.destroy_all, or using the rake destroy:topics_all_categories task to remove all topics while preserving users and categories. However, experts caution that directly deleting data can be risky and may break the forum. An alternative solution is to export user emails, reinstall Discourse, and invite users via bulk import. The discussion highlights that preserving user data without re-inviting them requires custom scripting, which is complex. Canapin and pfaffman provide detailed guidance on safe deletion methods, while leonardo recommends the rake destroy:topics_all_categories task as a safer option. JammyDodger and Canapin suggest that exporting users and re-installing may be the most reliable method, especially given the user’s small community of 550 users.
Hi!
When I created my forum, I didn’t think about the server being full, I thought it was automatically cleaned, I also didn’t know about copyright issues, problems with justice among other things, and even less did I go after information to not allow users of my forum to upload images to the server!
It turns out that now I’m going through several problems, full server, problems with the fairness of exposing images of others without rights, problems with copyright
I would like to know, how do I delete everything, all topics, all posted images, all images of members’ avatars, all files etc and only leave the discourse files (to run the forum) and the users
it is possible? What can I delete and what can’t I?
which command do i use?
I know it will remove little but I need it! I want to reset everything on my forum, and that won’t happen again, because I’ll set it up so that no one posts anything in the media.
How do you think your users would feel losing badges for posts, likes, etc? Eliminating all your content is both risky technically, and raises the possibility you’re going to alienate your users.
Just how big is the site now in terms of users, categories, and posts?
If you’re dead-set on this then consider hiding the current categories by changing permissions to staff only, and creating new public categories for posting.
In addition to what I told you, this forum belonged to another owner, so, for me, it would be better to do a reinstallation from scratch, but keeping the users, how do you do it?
I’m afraid my migration skills are non-existent, so even though I suggested it I unfortunately don’t know how to do it. I was hoping someone else would jump in to at least confirm it’s possible. Anyone?
How many users do you have?
If you have to start again from scratch, an alternative would be to export your users’ email addresses (using data explorer for example) as a CSV file, re-create your forum, and bulk invite your users using the CSV file.
Another idea, more difficult, and I’m not sure it would work as I think it should.
Export all your users’ data you want to keep (since you don’t want to keep their avatar, maybe you want to skip other information as well) using data-explorer and export the result as a file.
Then, after installing your new forum, create a rails script that will parse the file and create user entries in the database (as well as their options, emails…).
Here’s an example of user creation in the rails console:
oh yes, when they talked about it, I thought it was exact and easier, so I’ll have to go back to my first option: deleting things on the server! Do you know what command I use to delete things on the server? And what folders can I delete? I want to delete everything, from media to topics, I just keep the same users, I don’t even want to keep the style of the forum, I really want to reset it.
I was thinking of using the ‘Export’ button on the /admin/users/list/active page to get the user list. Maybe dropping some uneeded columns from the csv, and then importing that ‘somehow’.
I don’t have much experience in discourse for that. I’m going to delete things on the server, what command do I use to delete the folder (if any) of all Discourse media? Including profile pictures, wall pictures, topics, chat messages, regular messages etc?
I don’t think there is any way to do that more easily than exporting your users and reinstall Discourse from scratch, and then importing your users “somehow”
What data do you want to keep from your users, and how many users so you have? The more precise you are, the most likely you’ll get accurate replies to try to solve your issue.
I’m using google translator, I don’t know if it translated correctly, but from what I understood, they wouldn’t return to the forum, but would they be invited? I wanted to keep them the same, no invitations. I didn’t understand the translation exactly, does it matter in what way?
