Hoe de basiskleur in de titel uit te schakelen?
A user asks how to disable the gray color for visited topic titles, wanting them to remain black instead of changing to a lighter shade of the primary color. merefield explains it’s due to the visited link state and suggests using the browser’s inspector to override the CSS. pfaffman notes this would remove a key functionality for users. JammyDodger shares that they find the behavior annoying. darkpixlz provides a CSS fix to force the title color to the primary color, which tmn confirms works after correcting a typo in the code.
Hello everyone in support box.
The title of Topic visited will have gray color. I just want same black color. How to disable it function?
Thank you for your help.
It’s because you’ve looked at those Topics.
The links are in “visited” state.
Can I suggest you start to look at your Browsers Inspector? You will see the CSS rules there. Then you can override in your theme.
So you don’t want your users to know which topics have new posts in them? That’s a pretty big functionality that you would be removing.
I’m afraid I don’t know the answer, but I’m on a site that has done this (by accident or by design, I do not know :slightly_smiling_face:) and I find it super annoying. :slightly_smiling_face:
I know that big function.
Just because When I select primary color, for example dark Blue. The visited title will show Lighter Blue.
Dark Red → will show red
Only pair Black → show Gray still look ok.
Could you help for fix that?
Also not sure why you would want to do this, but here you go
.topic-list-main-link a.title, .topic-list .main-link a.title, .latest-topic-list-item .main-link a.title {
    color:var(--primary) !Important;
I agree with everybody above, thsis would be very annoying to me as an end user but you do you.
Thank so much. It worked like a charm.
I edited Important; to become important;
i am really appreciated for your support :heart_eyes:
Yeah, looks like a typo on my end, sorry!
I recommend putting the end user first, but if this is what you want for your forum go ahead, we cant stop you :slight_smile:
