How to disable tooltip?
I want to say that Russia does not like tips, nobody reads them.
I see that you can change them but do not know how to remove
there is no delete button
Have you tried putting an empty string there?
No, I think will be an empty window prompts the obvious
422 Unprocessable Entity
There is no support for disabling tooltips at the moment.
sorrowfully
and you have an idea how to remove?
I suppose some JavaScript that removed title / alt attributes could be used.
But my question is why? Is this really that much of an issue?.
No need to function
sense to leave her
so that there is a solution?
You can hack source code so they will disappear.
I’m not a hacker to crack :confused:
You don’t need to be. Just use your brain and github. There will be a code for showing that tooltips. Translation keys would be a good start.
I checked it from Github, discourse/lib/composer_messages_finder.rb looks interesting. There are functions which decides to show which message imo. Probably this is what you need.
해결 방법은 테마 구성 요소를 사용하여 해당 화면을 숨기는 것입니다. 또는 사이트 설정에서 default other skip new user tips를 활성화할 수도 있습니다.
