[I am not allowed to put more than two links into the body even though they are local, sorry… I used the search terms below on Search results for '' - Discourse Meta without quotes.]
There supposedly is a operator to negate search terms, according to New search operator "not" but the thread is very unclear what symbol was chosen in the end and there are no final examples. It is the first and pretty much only thing I could find online about it.
The thread talks about “-”, “!” and “~” so I tried them all:
“negative search” gives me 43 results with “negative” and/or “search” in them, the terms are highlighted
“-negative search” gives me 43 results with “negative” and/or “search” in them, “search” is highlighted
“-negative -search” gives me 43 results with “negative” and/or “search” in them, neither is highlighted
So whatever the highlighting means, the “-” symbol is not the operator.
I repeated the same tests with “!” instead, same results.
With “~” I get the same as before for “negative ~search” but zero results for “negative search”.
That topic definitely went through numerous changes. Sorry it is so confusing.
At this time, the negation operator is -, and it only applies to tags. So you can search for topics that do not have a certain tag, but cannot search for topics without a word, or category, etc.
The negation operator is used like so:
green tags:eggs -tags:ham - search for posts containing the word “green”, tagged with eggs, but not tagged with ham.
The following is not a valid search:
-green tags:eggs. While the intent may be to search for posts without the word green tagged with eggs, it will instead search for posts with the word “green” and tagged with eggs.
Essa funcionalidade de realizar uma busca sem uma palavra específica está prevista? Eu também preciso dela. Tenho tópicos que informam às pessoas [DONE] Título A. Agora, quero garantir que eu possa pesquisar todos os tópicos de um usuário sem a palavra DONE no título do tópico.
