New search operator "not" for tags only
Over at Stonehearth we’ve started to have the want to search for topics that don’t have a certain tag on them, or that aren’t by a certain user. To the best of my understanding, this isn’t currently possible. As such, we’d like to request a negation operator for search, like Google support -.
「いいね!」 17
So this just came up naturally from another user at Stonehearth:
Seems he was trying to search for “frog”, but we have a very active user named “froggy” so he had a hard time searching for posts that had frog but weren’t mentions.
「いいね!」 3
I’m amazed this topic didn’t get any more traction…
As the Keyboard Maestro forum gains more and more threads it’s becoming increasingly difficult to find things efficiently.
A negation operator would be helpful.
-Chris
You can use negation in Google searches with the site: operator, so try that. Visit the 404 page (type any random gobbledygook as a URL past the domain name) to get a pre filled google search form.
It is actually a pretty straight forward change (add support for -test) which would be only about 10-20 lines of code including tests (as long as its not in the advanced page with a fancy UI). Going to put a pr-welcome on this, I don’t think it would do any harm.
「いいね!」 4
Using google wont work for login-only forums, or secure categories
「いいね!」 6
That does not apply to the forum in question at https://forum.keyboardmaestro.com
So they can easily kick off a search with negation by going to https://forum.keyboardmaestro.com/nf
「いいね!」 1
Hi, I am quite new to the project, but I can try to add this feature.
「いいね!」 2
That’s great @kasiabulat. Do you have a good idea of where to start with this or do you need some guidance?
Thank you @erlend_sh for offering help! I think that the best and easiest way to do it would be to perform two searches:
  • Firstly, search for the term before the not part
  • Then, in results, search for the ones containing the unwanted phrase and filter them out
Is https://github.com/discourse/discourse/blob/87c334c06365f273f39038d91ab92488c4757041/app/assets/javascripts/discourse/widgets/search-menu.js.es6 the correct file to make changes in?
「いいね!」 1
The larger part of your changes will be in
https://github.com/discourse/discourse/blob/master/lib/search.rb
「いいね!」 11
Thank you @cpradio for help with finding the correct file.
For the beginning, I added a simple version of search operator “not” (~) for tags. Currently it has the highest precedence and I implemented it as I described above. But I am wondering if it would be better for ‘+’ or ‘,’ to have higher precedence? And should it be possible to combine all operators? What way would be the best for users to construct their queries?
Pull request: https://github.com/discourse/discourse/pull/5467
「いいね!」 4
I added some tests and comments about the performance issue to my pull request.
「いいね!」 5
I’m not sure about using ~ to represent NOT since it is usually used when matching against regular expressions. In Ruby, we use =~ /^some_regexp_pattern/ and it is similar in Postgres as well.
Screenshot%20from%202018-02-22%2018-03-34
I agree that using ~ as operator probably isn’t a good idea.
@kasiabulat Why did you choose ~ instead of - as “not” operator?
I’d prefer tags:eggs-lunch+sandwiches or tags:eggs!lunch+sandwiches to tags:eggs~lunch+sandwiches
「いいね!」 1
Ah ha this was probably not chosen because - are allowed in tags.
Using quotes would help: tags:"boiled-eggs"-lunch+sandwiches
Probably not the best idea to require quotes as a naive search on tags:boiled-eggs would no longer do what you’d expect. Is there any conflict with !? That would be my preference here.
「いいね!」 4
Should I change it into “!”, then?
「いいね!」 2
I added a commit with the proper change: https://github.com/discourse/discourse/pull/5467/commits/d01f064cf5c0a167876c1f9bd4730a3af951795d
「いいね!」 6
