Hello, I am very new to a self hosted discourse so might be missing something obvious. How do I edit WELCOME TO OUR COMMUNITY text in Air theme? If I go to site texts section and type this text to bring a string, it does not bring a such string but similar texts. Thanks!
לייק 1
Hey, welcome noid!
This text is part of a Search Banner theme component included by default with the Air Theme.
Go to: Admin → Components
Search for “search banner”, and you can see below the settings the translation you’re looking for:
2 לייקים
Awesome! Thank you very much, that worked well changing the wording. But would it possible to change a font size or even color?
It’s possible. There is no setting, but you can add some CSS in your theme or another new theme component:
For example:
.search-banner .custom-search-banner-wrap {
h1 {
/* CSS for the title */
font-size: var(--font-up-6);
color: aliceblue;
p {
/* CSS for the description */
3 לייקים
