What’s the recommended way to get a user’s avatar from their username in a plugin?
I did find some reference to lookupAvatar(username)
in quote.js.es6, but there doesn’t seem to be much out there regarding avatars.
ok, so I was able to get the avatars to work using:
const opts = helper.getOptions();
opts.lookupAvatar(username);
which works and will display the avatar in the post, but will freeze up the preview when composing a new post/reply.
Any help would be appreciated. Thanks!
How did you get helper?
