Hey there community!
By any chance has anyone wrote a query using Data explorer to fetch monthly pageviews number?
Is there any other programatic way to get those numbers than manually accessing my dashboard?
This is the query behind the Consolidated Pageviews report, I hope it helps.
-- [params]
-- date :start_date
-- date :end_date
SELECT
ar.date,
CASE
WHEN ar.req_type=6 THEN 'Crawlers'
WHEN ar.req_type=7 THEN 'Logged in users'
WHEN ar.req_type=8 THEN 'Anonymous users'
END,
ar.count AS views
FROM application_requests ar
WHERE req_type IN (6,7,8)
AND ar.date::date BETWEEN :start_date::date
AND :end_date::date
ORDER BY ar.date ASC, ar.req_type
This query lists the total number of pageviews over the period.
-- [params]
-- date :start_date
-- date :end_date
WITH data AS (
SELECT
ar.date,
CASE
END AS Pageview,
ar.count AS views
AND :end_date::date
SELECT Pageview, SUM(views) qtt_views
FROM data
GROUP BY Pageview
Perfect! That was what I was looking for.
Got one more question actually. Maybe that won’t be much of a hustle.
Is there a way to get the results in following format so using sum:
Yes, it is possible, in this case, you need to adjust the format of the date field first and then adjust the group by. Below is the adjusted query.
-- [params]
-- date :start_date
-- date :end_date
WITH data AS
(SELECT
date_part('month', ar.date) AS month,
date_part('year', ar.date) AS year,
CASE
END AS pageview,
ar.count AS views
AND :end_date::date
SELECT
month,
year,
sum(views) AS qtt_views
FROM data
GROUP BY year, month
ORDER BY year DESC, month ASC
| month | year | count |
| 1 | 2021 | 1000 |
| 2 | 2021 | 500 |
| 1 | 2020 | 1500 |
| 2 | 2020 | 2000 |
| 3 | 2020 | 2500 |
Perfect! Thanks for help!
