Hello,
is there some way, maybe due a CSS hack, to hide the “uncategorized” category?
This category is disabled by default. It has no content and couldn’t be removed at all.
Thank you
If Uncategorized is disabled, then non-staff users will not see it in the hamburger menu, but staff will see it regardless of the setting (not sure why though
But if you want to hide it from your staff too, then here is CSS code to hide it:
.category-uncategorized {
display: none;
Thanks! This confused me a lot ![]()
Hi
Probably stupid question, but could you tell me where I should add this CSS code into?
Thanks a lot.
V
Hi
Go to Admin > Customize > Themes and create a new theme and then click on Edit CSS/HTML and add the CSS code under Common > CSS. Finally make the new theme a component under your default theme. Hope this helps! ![]()
Hmmm.. this looks correct to me, not sure what’s going on. Is your site private? If not, I’d be happy to take a look for you.
Wooooo I got it! I had to disable posting topics into uncategorized category … in admin! Done! Thank you kindly for your help!
V
